_Phil_
Dec 05, 2017Aspirant
FTP Folder Names Problem
I can connect to the FTP just fine on my ReadyNAS 204 but the folders are shown with long names full of Unix information. For example a folder that should show up as just "FTP" instead shows up as.....
- Jan 16, 2018
OK, well there's at least two "solutions", and thanks to all for the help.
1. Use a client that used LIST instead of MLSD, e.g. CoreFTP.
2. Change the FTP user primary group in AD to have no space in it. This could be a new group, which is what I did instead of renaming "Domain Users".
Cheers.
tnorton00
Jan 10, 2018Guide
I'm having the exact same issue. CoreFTP works just fine. Netgear refuses to accept that their update did something.
_Phil_
Jan 10, 2018Aspirant
tnorton00 wrote:I'm having the exact same issue. CoreFTP works just fine. Netgear refuses to accept that their update did something.
You have saved me, CoreFTP works for me too! That is such good news for me, thankyou for letting me know. I think you're right, one of the updates broke this as it used to work fine. I wonder what it is about CoreFTP that means it reads it correctly? Thanks again!
- tnorton00Jan 10, 2018Guide
You're welcome, Windows FTP browsing works fine as well FYI.
- Marc_VJan 11, 2018NETGEAR Employee Retired
Hi All,
As posted from tnorton00 's post
Issue is with FTP Clients using MSLD command to retrieve file/folder information. FTP Clients using MSLD command cannot handle Domain users whose Primary group name contains a space e.g. "Domain Users".
Workaround is either to change the Primary Group name or use a FTP client that uses LIST command.
Hope this helps
Regards!
- tnorton00Jan 11, 2018Guide
Very strange, I had no issues with FileZilla with firmware 6.7.1 and older but changing to 6.9.1 gets installed and FZ gets this issue but the problem is with FZ? Seems fishy.
