plingis30000
Sep 13, 2011Aspirant
Problem with moving file(s)
Hi!
I´m having a problem when I try to move an existing file in a share to another directory in the same share. I get the message:
Cannot move file XXX: Access is denied.
Make sure the disk is not full or write-protected and taht the file is not currently in use.
I have just upgraded the raidator to : RAIDiator 4.1.8 [1.00a043]
When looking into the share list the following rights are set:
CIFS-read/write - AFP-read/write - HTTP/S - read/write (rsync -only read)
Does anyone know if there are known problems with that new version of raidator?
I also wonder if there are possibilities to install an older firmware?
Best,
Magnus
Best,
Magnus
- plingis30000Aspirantanyone?
- ewokNETGEAR ExpertIt sounds like a filesystem level permissions problem. What are the permissions on the file, source folder, and destination folder?
ewok wrote: It sounds like a filesystem level permissions problem. What are the permissions on the file, source folder, and destination folder?
Permissions:
the file = read/write
source folder = read/write
destination folder = read/write
//Magnus - ewokNETGEAR ExpertRead/write for which user(s) and group(s)?
ewok wrote: Read/write for which user(s) and group(s)?
Hi!
Thanx for asking. It was solved a few days ago... I don´t remember exakt how I did but I think I moved into:
* Share -> Share list -> CIFS and there chose advance alternative? and clicked ownership? And last applied it...
Best,
Magnus
