vollprofi1
Dec 28, 2016Tutor
Problem with ReadyDLNA and music streaming
Hello all together, up to lasr week I used an old RaydyNAS Duo as sreaming server for my music archive. Since last week I use my RN214 instead of that. I copied all files from my old NAS to the 214....
vollprofi1
Dec 30, 2016Tutor
Sorry, but this cannot be the problem:
With my old ReadyNAS DUO with exactly the same files (just copied as I mentioned) this problem did not appear...
Another idea? Is there a possibility to configure the ReadyDLNA?
Dec 30, 2016Guru - Experienced User
I think you'll find it is the issue. Try it on one album and see if it fixes it (remembering to rescan).
I understand that the ReadyNAS duo didn't have that problem. But I believe it was running a different version of ReadyDLNA.
I don't know of any way to modify this behavior. You could try using plex instead.
