admin008
Dec 30, 2014Aspirant
Problem with Replicate across WAN
Hi I have a problem with backing up across the WAN using the "replicate " software" it has been generally reliable (I only have one active job setup)- but recently I am getting a failed status ...
Nhellie
Dec 30, 2014Virtuoso
Are there anyone using these files when being replicated? If a file is modified before finishing the replication, it is normal to get "failed" error message since the original file intended to be copied/replicated has been altered.
