WillidsNet
May 27, 2020Aspirant
Problem with Shares
I have setup the accounts and shares, I need a couple of folders protecting from anyone else on the network.
When I go to the PC and view Network > Named Network > I see , All Folders, data (folder shows all folders including hidden ones) & home
I have managed to hide some folders using shares > folder name > settings > network access > SMB > Advanced > hide folder
The problem is users can still access the folders (in data folder) which they do not have permission to see, also some of the information is confidencial so the second question is can I encryt a folder so only those who have access to (network IP address or other means) can see it.
Running Windows 10, ReadyNas 6.10.3 (RN31442D, 4 x 2TB drives)
Have folling available on folders for Network Access > SMB, NFS, AFP, FTP, RSYNC, HTTP, DLNA, iTUNES
Access will always be via computers and not interenet remote access.
Any help is sorting this out to limit access to users and being enable to encrypt a folder would be gratefully accepted. If I have to set the NAS up again I can do so, since the information needs to be made secure and limit users anything can be done to get this sorted (unless it means spending money)
I have created a user called Protected and had to create a folder since the nas did not create the user folders automatically.
- Marc_VNETGEAR Employee Retired
Welcome to the Community!
You will have to set permissions on the shares. Here's a good FAQ page for that.
https://kb.netgear.com/29838/ReadyNAS-Share-and-Permission-FAQ
HTH
- WillidsNetAspirant
Marc_V wrote:Welcome to the Community!
HTH
Thank you for the reply, I have tried that and other users can still see it and gain access to it.
If your users are seeing the "data" folder, then they are using the NAS admin credentials. If you want to restrict their access, they need to use different credentials.
First create at least one new NAS account for them to use in the web ui. Then change the NAS admin password so their current admin credential will fail.
Then test access to the shares using the new NAS accounts.
I'm not sure exactly what you tried, but I recommend managing share access using network access rights alone (leaving the file access permissions at the default settings). https://kb.netgear.com/26453/ReadyNAS-OS-6-Set-Network-Access-Rights-to-Shared-Folders
