Anaardvark
Oct 22, 2013Follower
Problems adding 4th drive (NV+ V2)
I'm having problems adding a 4th drive.
In the NAS already is a 2GB Samsung drive and 2x WD Red 2TB drives using X-Raid 2 this has been working perfectly, however I bought and added a 4th WD Red 2TB drive, but the total still reads 3.6TB. the Drive info is as follows:
Disk 1 WDC WD20EFRX-68AX9N0 1863 GB (29 °C / 84 °F, Write-cache On). Status: OK
Disk 2 SAMSUNG HD204UI 1863 GB (30 °C / 86 °F, Write-cache On). Status: OK
Disk 3 WDC WD20EFRX-68AX9N0 1863 GB (30 °C / 86 °F, Write-cache On). Status: OK
Disk 4 WDC WD20EFRX-68EUZN0 1863 GB (27 °C / 80 °F, Write-cache On). Status: OK
I've tried restarting the NAS but it's not spanning across to the 4th volume. I also tried updating the firmware to 5.3.8 (from 5.3.7) and then restarting it but it still isn't doing anything. What am I doing wrong?
Thanks.
Thanks.
- evan2NETGEAR Expert
Could you download logs in UI? then send email
- evan2NETGEAR ExpertI find some problem in your disk (0-4096, input/out error) , so the disk don't create partitions after install,
Please contact support, maybe we need to remote access your NAS to fix the disk.
Error:
/dev/sdd: read failed after 0 of 4096 at 0: Input/output error
/dev/sdd: read failed after 0 of 4096 at 2000398925824: Input/output error
/dev/sdd: read failed after 0 of 4096 at 4096: Input/output error
No partitions on sdd
***** Disk partition log for channel 3 [sdc] *****
Disk /dev/sdc: 3907029168 sectors, 1.8 TiB
Logical sector size: 512 bytes
Disk identifier (GUID): DC540451-CC4A-46B4-9F1D-36BFC3954E4A
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 3907029134
Partitions will be aligned on 64-sector boundaries
Total free space is 4092 sectors (2.0 MiB)
Number Start (sector) End (sector) Size Code Name
1 64 8388671 4.0 GiB FD00
2 8388672 9437247 512.0 MiB FD00
3 9437248 3907025072 1.8 TiB FD00
# partition table of /dev/sdc
unit: sectors
/dev/sdc1 : start= 1, size=3907029167, Id=ee
/dev/sdc2 : start= 0, size= 0, Id= 0
/dev/sdc3 : start= 0, size= 0, Id= 0
/dev/sdc4 : start= 0, size= 0, Id= 0
***** Disk partition log for channel 4 [sdd] *****
Creating new GPT entries.
Disk /dev/sdd: 3907029168 sectors, 1.8 TiB
Disk identifier (GUID): 5AE5B179-1AAD-4EED-BDD2-271C768C1A07
Partitions will be aligned on 2048-sector boundaries
Total free space is 3907029101 sectors (1.8 TiB)
