Nyflgirl's avatar
Nyflgirl
Problem with adding satellite
I have my Ac3000 set up and working. I wanted at add a 2nd satellite so I got a rbs40. I have it all hooked up and it’s showing both satellites online, however if the rbs40 is plugged in and you are near it, you can’t connect to the wifi. When I unplug the satellite I can access the web. Does anyone know why this is happening and how to fix it?
  • Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password.
    Can you get logged in and see the FW version here?
    • Nyflgirl's avatar
      Nyflgirl
      The orbi app is showing it online. If I plug in the satellite I lose internet, my phine shows the internet but I can not go online. if I unplug it the internet is available again.
    • Nyflgirl's avatar
      Nyflgirl
      I can’t see if it would be connected via Orbi web interface (http://orbilogin.net), When I plug it in, and try to interface, nothing happens. It won’t connect to the orbi router. It seems like the satellite blocks the wifi connection for anyone near it.
      • FURRYe38's avatar
        What FW version is loaded on the 50 series system? Possible the FW is newer than whats on the 40 series RBS which probably needs to be updated...
