timvd
Nov 09, 2011Aspirant
Problems after expansion
I have an Ultra 4, which had until recently 3 x 2TB WD EARS in an X-Raid setup. I got a brand new 2TB EARX which i put in, and the has started the expansion. But it didn't expand the volume, only the ...
ReadySECURE
Nov 09, 2011Apprentice
Hello,
The EARX hard drives are not on our compatibility list, which is why you are experiencing issues. Also there is only one model of WDEARS drives that are compatible with the ReadyNAS. Only Model # WD20EARS-00S8B1, and on only Firmware version 80.00A80 is supported. If your WDEARS are not the model listed this could be a cause of the problem as well. Please review our compatibility list for compatible hard drives.
- http://www.readynas.com/?page_id=82
Support Resources -
Forums:
Prosafe: http://forum1.netgear.com
ReadyNAS: http://www.readynas.com/forum
Prosecure: http://prosecure.netgear.com/community/forum.php
Contact support or register a device
1-888-NETGEAR (638 - 4327) Option 4 for technical support
http://my.netgear.com
Knowledge base
http://support.netgear.com
Support Resources -
Forums:
Knowledge base
