Cybermoose
Dec 26, 2011Aspirant
Problems after I upgraded to Logitech Media Server 7.7.1
Hi I ugraded to Logitech Media Server 7.7.1 today and it totally messed my Readynas 6 Ultra. I followed the instructions and first unistalled 7.7.0 then I run the clearsqeezebox and then installed ...
virgiliomi
Mar 09, 2012Aspirant
The fixes are available in beta versions of RAIDiator (4.2.20) and Logitech Media Server (7.7.2).
The root issue is caused by one of Netgear's startup scripts, and other add-ons have also caused this issue, not just LMS. LMS ran into the issue in 7.7.1 because they changed the location of some of their cache and temporary files. In 7.7.2 they changed the location again, this time to a hidden folder (a . as the first character) in the same location as 7.7.1.
So if the only add-on you use is LMS, and you just want to have your Media share back, download and install the latest nightly build of LMS 7.7.2.
If you also use other add-ons that might run into this issue and don't want this problem to occur again, you may want to get RAIDiator 4.2.20 from the Beta forum here instead. You may want to read through some of the beta threads though, as there are some people reporting other issues that could significantly impact the performance of your ReadyNAS depending on the model you have and what features you're using.
