olavlind
Jan 20, 2014Aspirant
Problems opening files on NAS in Word from OS X
Hi, We recently changed from ReadyNAS Ultra 4 to ReadyNAS 316. I Set up a backup job on the 316 to pull all data from the Ultra 4 using NFS protocol. After changing over, pointing all users to th...
xeltros
Jan 21, 2014Apprentice
I'm on mavericks 10.9.1, with RN104 with 6.1.6RC10. So my setup is quite similar to yours except I have an ARM CPU and I have no problem. I checked with AFP (my default since I have a Mac) and SMB and both work flawlessly with .docx files.
So I think SMBplus won't do anything and depending on the windows versions you use downgrading smb protocol mays not be a good idea.
Can you try with AFP, with a document you know is opened by you mac locally ? As I said earlier I think the message said it couldn't open word, not that word couldn't open the file.
