olavlind
Jan 20, 2014Aspirant
Problems opening files on NAS in Word from OS X
Hi, We recently changed from ReadyNAS Ultra 4 to ReadyNAS 316. I Set up a backup job on the 316 to pull all data from the Ultra 4 using NFS protocol. After changing over, pointing all users to th...
xeltros
Jan 21, 2014Apprentice
1°) unless you did set things manually on each folder in which case your settings may be erased, I believe it's safe.
2°) probably, not sure if this reload the service at the end.
