olavlind
Jan 20, 2014Aspirant
Problems opening files on NAS in Word from OS X
Hi, We recently changed from ReadyNAS Ultra 4 to ReadyNAS 316. I Set up a backup job on the 316 to pull all data from the Ultra 4 using NFS protocol. After changing over, pointing all users to th...
olavlind
Jan 24, 2014Aspirant
Case solved.
There seems to be bugs in the Apple Samba implementation, and the AFP protocol would not come up.
What I did was reset permissions on the share. Then I connected to the shared folder on the NAS using AFP from finder.
That seemed to fix everything. All is now working as it should.
~Olav
~Olav
