davidr1's avatar
davidr1
Luminary
Sep 10, 2015
Problems setting up NAS31400
Hi,   I just bought the 31400 and two 4TB WD RED WD30EFRX.   1. It is doing a Resync (presumably building the XRAID2 array?).   2. After about 5% it showed the IP address alternating with the R...
  • StephenB's avatar
    Sep 26, 2015
    I was thinking you meant your legacy NAS upgrades.  Personally I'd wait a bit longer, but that of course is your call.  If you have more than one NAS, then maybe try it on one first.
    Software updates work the same way as before.  You won't get notifications on beta updates, but you should on production releases.  And of course you can manually install from the web ui.
ProSupport for Business
