Bob33Builder
Nov 01, 2020Aspirant
Problems trying to run ReadyNAS Duo V2 with Firefox and Windows 10
After trying unsuccessfully to run my old ReadyNAS Duo V2 and use it for sharing pictures, I shelved it again for future consideration. I posted a thread here about 10 - 11 months ago and got nowhere...
Bob33Builder
Nov 02, 2020Aspirant
Thank you,
I can access it from my Samsung tablet no problem. But I want to use my laptop, not my tablet. I didn't try another computer.
I can access it through MS Edge if I click away all the warnings about an unsafe site.
FireFox, my browser of choice, simply completely blocks me from accessing my own device, sitting on my desk 6 inches from my computer. So annoying!
The firmware is v5.3.13
When I had it open in Edge, I tried exporting the certificate that was created for Edge. Apparently a self signed certificate. I do not understand how these things are created and verified.
Using the export certificate function in Edge, I saved it in 2 different formats and tried to import them into FireFox. Neither one worked, FF wouldn't let me import them.
I forgot to mention, I run Kaspersky Total Security.
Thanks for your help.
Sandshark
Nov 02, 2020Sensei
PR_CONNECT_RESET_ERROR is not a certificate problem. It's telling you that somehting between the browser and NAS is blocking the connection, and the most likely candidate is your security software. Try disabling Kaspersky Total Security. If that fixes it and Kaspersky has separate settings for different programs, that's where you should look for a permanent solution.
Once you get past this issue, you'll still have to deal with the self-signed certificate.
- Bob33BuilderNov 02, 2020Aspirant
I tried disabling Kaspersky and running it again, but I got the exact same error message.
Then I shut everything down, rebooted the computer and then disabled Kaspersky first, then opened FF and attempted to access the NAS, but got the same results.
I just repeated the same thing I have already done and tried again to access the NAS.
Rebooted, disabled Kaspersky, launched FF and tried to access the NAS.
This time I got this message:
Secure Connection Failed
An error occurred during a connection to 192.168.0.25. Peer using unsupported version of security protocol.
Error code: SSL_ERROR_UNSUPPORTED_VERSION
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the website owners to inform them of this problem.Learn more…
This website might not support the TLS 1.2 protocol, which is the minimum version supported by Firefox. Enabling TLS 1.0 and TLS 1.1 might allow this connection to succeed.
TLS 1.0 and TLS 1.1 will be permanently disabled in a future release.
- SandsharkNov 02, 2020Sensei
See potential solutions here: Readynas-duo-V2-unable-to-access-admin-page
and here: ReadyNAS-NV-V2-TLS-Support-may-not-be-able-to-access-soon
These are really stopgap solutions. Long term, you should look at replacing the NAS with one that runs a more up to date OS.
