herfjord
Oct 06, 2012Aspirant
Problems when connecting to rsync/SSH from server
Dear all, I'm struggeling to connect to my ReadyNAS from a CentOS server by rsync through SSH. It works great without SSH, but I'm going to perform the backup over the internet, so I have to use SS...
herfjord
Thanks for the feedback :)
I'm using RAIDiator 4.2.19, and yes, it's actually a ultra with the $0.99 add-on.
I have it working the other way around, means the ReadyNAS is able to push files to my CentOS over SSH (after importing the key as thrusted and so on..).
From my CentOS:
I Installed my server a couple of days ago, and I trusted my resposetories to download the latest version, but I see from the official website of rsync that the latest version is 3.0.9, and 3.0.6 is as old as May 09.
I will try to update both my CentOS rsync and the RAIDiator to see if it helps.
Again, thanks for your feedback, and I read between the lines that you mean I have done it right with the syntax..?
BR
Henning
From my CentOS:
# rsync --version
rsync version 3.0.6 protocol version 30
BR
Henning
