Squazz
May 06, 2015Aspirant
Problems with access after reinstall of Windows
So, I have this Readynas Ultra 4. When I was on windows 7 I created a bunch of shares to keep track of my different types of files. Back then I didn't have extra users on the NAS, I was the only us...
vandermerwe
May 06, 2015Master
After you changed the owner etc., did you update the permissions using the checkbox that is on the advances tab in share properties?
Also, the easiest way to set this up is to have users on the nas that match those on windows.
What firmware are you running?
- Jul 15, 2018Retired_Member
