royjohn8
May 04, 2013Aspirant
Problems with FTP access
Hi there, Hoping there is a guru out there who can help me out. I am trying to set up remote access to my Readynas and connect via FTP using Filezilla. I thought my settings were correct but I a...
May 04, 2013Guru - Experienced User
Ok.
royjohn8 wrote: Thanks for the response.
I have disabled masquerading on the NAS and set "use the server's external IP address instead" on Filezilla.
With filezilla I can connect to NAS on local LAN no problems (to internal, local IP)
However, still no success with connecting with filezilla remotely using above mentioned settings.
(FZ:"connection timed out", "could not connect to server")
The next step is to use http://www.canyouseeme.org/ on a PC connected to your local LAN, and use it to confirm that port 21 is open. My guess is that your ISP blocks it.
You can try configuring the NAS to use port 5000 for FTP (adjusting the passive port range to 5001-5050). Also change FileZilla to use port 5000.
