dschwartzer
Feb 01, 2017Luminary
Promoted Snapshots
I am running an RN526X with firmware 6.6.1. After a lot of help from this community I got the snapshots working correctly. My system takes a daily snapshot of all of the shares (except the Home fol...
- Feb 02, 2017
dschwartzer wrote:
How do I know which are daily, weekly and monthly?
They are all the same. One of the daily snapshots isn't deleted (becoming the weekly one), and one of the weekly ones isn't deleted (becoming the monthly).
dschwartzer wrote:
Any other ideas?
Perhaps manually prune the really one ones, and wait about a week to see if the February snapshots are pruned. The processing might not clean up old missed snapshots.
You could easily switch to custom snapshots - there is no thinning, but there is a setting to prevent needless snapshots (when there are no changes to the share contents). You can limit total retention, which is something that you can't do with the smart snapshots.
Feb 01, 2017Guru - Experienced User
Is the system powered down at night?
dschwartzer
The snapshots occurr at midnight and the system powers down at 1:00 am.
- StephenBFeb 01, 2017Guru - Experienced User
You should be ok then, so I am a bit puzzled. Do you have disk spindown enabled? If so, maybe try disabling it from 12-1 am.
Personally I use custom snapshots, so I can limit retention.
- dschwartzerFeb 01, 2017Luminary
I do have spin down enabled but have it set to spin up for backups. That said, I will try to disable spin down between 12 - 1.
If that is the issue, will the system still do the necessary promotions of the snapshots it has or will they be ignored because the time has passed to promote them?
Also, I am not opposed to using Custom settings. Can you provide a suggestion on what is working for you?
David
StephenB:
I have disabled disk spindown and will see what happens tonight. Either way, I am confused by what the Snapshot page says and what I would be seeing.
Is there some naming convention that distinguishes a daily snapshot from a weekly snapshot or monthly snapshot? Do all the folder look the same? How do I know which are daily, weekly and monthly?
The Snapshot screen says:
- Daily snapshots are kept for a period of 4 weeks
- Weekly snapshots are kept for a period of 8 weeks
- Monthly snapshots are kept forever.
Does that mean that you could see daily, weekly and monthly snapshots in a folder at the same time?
David
- StephenBFeb 02, 2017Guru - Experienced User
dschwartzer wrote:
Any other ideas?
- dschwartzerFeb 02, 2017Luminary
StephenB:
As you suggested, I disabled the Spin-Down on the ReadyNAS from 11:00 PM until the uniyt shuts down at 1:00 AM. The Daily Snapshots are done at midnight.
That did not have any effect on the snapshots being promoted. The folders appear the same as my screenshot above except it now has an additional dolder for the 2/2/2017 snapshot.
Any other ideas?
David
