readyornot
Apr 24, 2012Aspirant
Proper Duo Network Config
I use my Duo v1 to run Backup on several desktops at home. Name resolution has been hit-or-miss over the years, and before I upgrade to a x86 product I would like to see if I can make this old box per...
Apr 25, 2012Guru - Experienced User
I use DHCP with my V1, and have never seen it complain about a bad IP. (I have WINS turned off btw).
I am wondering about your subnet mask on the Duo. If it is incorrect, then that could explain the internet access issue.
It might help if you provide more details on addresses, masks, etc.
