readyornot
Apr 24, 2012Aspirant
Proper Duo Network Config
I use my Duo v1 to run Backup on several desktops at home. Name resolution has been hit-or-miss over the years, and before I upgrade to a x86 product I would like to see if I can make this old box per...
May 02, 2012Guru - Experienced User
After the restart, the DHCP issue is resolved.
Maybe you can update us with the status on the other two issues?
