jazzmenrice
Aug 18, 2014Aspirant
Pulled wrong drive to replace, then shut down.... HELP!
ReadyNAS NV+ V1, only two drives installed: 1)500GB Seagate, 2)1TB Seagate Drive 1, the older 500GB Seagate, was nearing failure with growing bad sectors. I ordered a 1TB WD RED as a replacement. W...
mdgm-ntgr
Aug 18, 2014NETGEAR Employee Retired
If you add the disk while the NAS is on (hot swap) it will be wiped and added to the array.
Having said that now would be a good time to make sure you have an up to date backup.
