jazzmenrice
Aug 18, 2014Aspirant
Pulled wrong drive to replace, then shut down.... HELP!
ReadyNAS NV+ V1, only two drives installed: 1)500GB Seagate, 2)1TB Seagate Drive 1, the older 500GB Seagate, was nearing failure with growing bad sectors. I ordered a 1TB WD RED as a replacement. W...
jazzmenrice
Thank you, mdgm.
I will follow your advice and perform a usb backup before hot swapping.
(I do have up to date backup to ReadyVault - probably one of the few suckers still using Netgear's overpriced backup system but at least it works headlessly from the NAS.)
Thanks again for the quick reply!
Dan
Dan
