BJB
Jan 22, 2018Aspirant
Push vs. Pull Rsync backup
This FAQ How do I backup data between two ReadyNAS OS 6 systems describes how to setup a backup job on the source NAS to backup to another NAS. I have seen some posts where users are setting up ...
- Jan 22, 2018
BJB wrote:
I have seen some posts where users are setting up the RSYNC job on the destination NAS and "pulling" the data from the source. I didn't see an FAQ for this method.
It is pretty straightforward, you just need to reverse the source and destination in the faq. Ignore step 16, it doesn't apply.
BJB wrote:
What are the pros and cons of the two different kinds of setup?
One advantage of the "push" backup is that the source NAS will make a snapshot, and then back up the snapshot. That ensures that all the files are coherent (copied at the same time instant), and that a file can't change while it is being backed up.
If the backup NAS is on a power schedule (as mine are), then the "pull" backup ensures that the backup NAS is actually running when the backup starts, and that it won't shut down until the backup is finished.
Jan 22, 2018Guru - Experienced User
- BJBJan 22, 2018AspirantThanks for clarifying! I plan to use hard drive spin down but not a power schedule so I think push would be okay.
BJB - BJBFeb 21, 2018Aspirant
I was going to set this up when I realized something. My new RN424 NAS (now blank) should be my new source NAS for my video folder and my old NAS RN104 should be my "backup" NAS for this folder so I am writing to, and streaming from my new NAS in the future.
So I realized I need to copy that one video folder from the old NAS to the new NAS to start and then copy all new files to the new NAS going forward. Should I just do an explorer or teracopy for this one-time copy? Settying up a sync I don't think makes sense as in the future it will be going the other way?
I then think I need to free up some space on the old NAS so there is room for future Syncs of this folder from the new NAS as new videos are added.
So once I add new files to the new NAS I need these files copied to the now backup folder on the old NAS which up until these new file adds were identical. Can I keep what is there on the old NAS and add to it when I setup the sync or will it need to be an entirely new folder to get the sync going? If it needs to start with a clean folder then I will need to make sure is room for a one-time sync and then delete my original folder afterwards (which is scary to do..). Would prefer the sync just ADD files added to the new NAS to my old NAS so I can keep my original folder and files as they are...
Geez this sounds complicated...
Thanks again for the help and any suggestions.
BJB
- StephenBFeb 21, 2018Guru - Experienced User
Personally I've just used rsync share-by-share backup jobs to get the folders onto the NAS. Using explorer or teracopy will double the network load, since everything would be copied through the PC. Teracopy is more robust than explorer.
You can use the existing shares on the old NAS as the backup destination, there is no need to create new shares (or empty existing shares). It would make sense to turn snapshots off for the initial backup from the RN424 to the RN104.
Is the rsync backup setting the same for my inital "copy it all" sync from old NAS to new NAS as it is for the "copy just the new files" from the new NAS to the old in the future for backup purposes from that point on?
Of course other than the backup jobs are in different directions.
So Rsync never overwrites or deletes files, it just copies what is missing?
Thanks,
Bill
