BJB
Jan 22, 2018Aspirant
Push vs. Pull Rsync backup
This FAQ How do I backup data between two ReadyNAS OS 6 systems describes how to setup a backup job on the source NAS to backup to another NAS. I have seen some posts where users are setting up ...
- Jan 22, 2018
BJB wrote:
I have seen some posts where users are setting up the RSYNC job on the destination NAS and "pulling" the data from the source. I didn't see an FAQ for this method.
It is pretty straightforward, you just need to reverse the source and destination in the faq. Ignore step 16, it doesn't apply.
BJB wrote:
What are the pros and cons of the two different kinds of setup?
One advantage of the "push" backup is that the source NAS will make a snapshot, and then back up the snapshot. That ensures that all the files are coherent (copied at the same time instant), and that a file can't change while it is being backed up.
If the backup NAS is on a power schedule (as mine are), then the "pull" backup ensures that the backup NAS is actually running when the backup starts, and that it won't shut down until the backup is finished.
Jan 22, 2018Guru - Experienced User
BJB
Thanks for clarifying! I plan to use hard drive spin down but not a power schedule so I think push would be okay.
BJB
BJB
