Digital999
Jan 30, 2018Luminary
PuTTY connection
This definitely ranks as a ‘rookie’ question but I need some guidance. Unfortunately I am Windows literate and almost illiterate when it comes to Lunix systems. What I need is some help regardin...
mdgm-ntgr
Jan 30, 2018NETGEAR Employee Retired
The SSH user is ‘root’ (no quotes)
bedlam1
Jan 30, 2018Prodigy
Also Putty does not display anything when you type your password, once you have typed it hit enter
- Digital999Jan 31, 2018Luminary
Thanks to those who took the time to reply. The 'big' hint was that password entry is not reflected in the emulation screen as I expected.
The last time I used PuTTy was in 2015 with a program called Midnight Commander.
At that time, with the PuTTy emulator I had available, I was able to load the emulator and log on to "admin" with the system password.
Our use of PuTTy is low -- not used since 2015 and I want to verify what my research shows...
PuTTy will no longer open with a Windows shortcut that contains the password as part of the command line. Is that true?
"admin" account reference has been replaced with "root". That change has occurred in the past three years?
The password we use for every system is different and is about 16+ characters -- typical upper/lower/special. In the Windows environment we use cut/paste to enter the password if needed. For all practical purposes it is not possible to type the password correctly since the actual input is not reflected and keyboard input is subject to the fat finger syndrome.
Security is important but in this manner it is not paramount since the physical security essentially isolates selected Windows systems. Any recommendations for a way to establish a PuTTy connection, including the password, would be appreciated.
Ignore my questions -- I have determined an appropriate response.
Regarding the PuTTy login from a physically secure Windows system the following command line will work...
putty.exe -ssh [email protected] -pw mypasswordforsomewherecom
Obviously the executiable must be local or part of the Windows system environmental variables.
Once again -- a big thanks for those who responded.
- bedlam1Jan 31, 2018Prodigy
You can install Midnight Commander on the NAS
apt-get install mc
I use it myself as I am not very linux command literate
- ctechsJan 31, 2018Apprentice
The ssh account has been root for as long as I can recall. It's that case for the 4.2.x NASes we still own. You can paste into a PuTTY window with a right click. It does paste whatever is in the clipboard doing that, even though it doesn't reflect it in the display.
- StephenBJan 31, 2018Guru - Experienced User
OS 6 will accept admin as well, for most purposes you need to log in as root (and you can run into issues if you try to use admin).
