IcyK
Dec 02, 2012Tutor
Q: change raid0 volume name?
Hi all, I have an Ultra 2 with 2 x Raid0 drives, single volumes, volumes /dev/c and /dev/d. Today, I tried to updrade one of the disks: pulled out the left disk (/dev/c), put in a new one, made a ...
siigna
Dec 06, 2012NETGEAR Employee Retired
You'd have to get in via SSH to do it. Boot up with just the disk/volume you want to rename, unmount the filesystem, then use vgrename and lvrename to rename the volume group/logical volume. Make sure you've got your mount points in /etc/fstab and you should be good.
- Dec 25, 2018Retired_Member
