aaseef021
Jul 01, 2018Aspirant
Question related to my ReadyNas516
I had couple of questions if you can please answer please.
1. How can I update the Mono version and what is the latest version i can update to.
2. How to backup the whole readynas
3. Ho...
- Jul 10, 2018
A config backup restores the configuration for the in-built features, not for apps.
You'd have to note down/backup/restore your app settings/data separately.
If you're wanting to experiment doing things using SSH you're better off doing that initially in a Virtual Machine (e.g. in VirtualBox on your PC) that you can take a VM snapshot of allowing you to roll-back mistakes. Then after trying it out on the VM once you're happy with it give it a go on the NAS itself.
Jul 01, 2018Guru - Experienced User
I don't use mono. On the backup questions, you might want to read through these faq: https://kb.netgear.com/29788/ReadyNAS-Backup-FAQ
aaseef021 wrote:
4. Is it a good idea to do a factory restore
Sometimes, but not usually. Why are you thinking you should do one?
- aaseef021Jul 01, 2018Aspirant
Thank You for answering
Currently i have some apps installed that require a higher version of Mono, i currently have mono 4.5 i need to install 5.8 or later for this app to work correctly.
Also the backup and restore article is not very clear. I wanted to restore beccause I installed many thing and believe it is best to start over.
- StephenBJul 01, 2018Guru - Experienced User
That is one reason to do a default.
The first thing you need is storage you can use to back up the NAS. USB drives are a common way.
I suggest doing share-by-share backup of the public shares, either using the built-in backup in the Web Admin UI, or by using a PC tool that can copy and verify (teracopy is one tool that can verify). If you use a PC tool, then connect the USB drive to the PC, and back up over the network. If you use the built-in backup, it's usually easiest to connect the USB drive to the NAS.
The hardest files to back up and restore are the private "home" folders - do you use those?
After you've backed up the data, then spot-check each USB disk, and make sure it has everything.
Since you won't be reinstalling all the apps, it is best not to rely on the built-in ability to save/restore the configuration files. Instead, you should go through your NAS configurattion and document the settings (share names, permissions, etc). One useful way to do that is to make screenshots of the various screens.
How can I update the mono version to 5.8, i currently have 4.8.
