aaseef021's avatar
aaseef021
Question related to my ReadyNas516
I had couple of questions if you can please answer please.   1. How can I update the Mono version and what is the latest version i can update to.   2. How to backup the whole readynas 3. Ho...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Jul 10, 2018
    A config backup restores the configuration for the in-built features, not for apps.
    You'd have to note down/backup/restore your app settings/data separately.
    If you're wanting to experiment doing things using SSH you're better off doing that initially in a Virtual Machine (e.g. in VirtualBox on your PC) that you can take a VM snapshot of allowing you to roll-back mistakes. Then after trying it out on the VM once you're happy with it give it a go on the NAS itself.
ProSupport for Business
