Kish
Mar 22, 2013Aspirant
Questions about OS 6
After reading up on Btrfs, I also do NOT understand the logic in not allowing current ARM and x86 Series owners to upgrade to OS 6. Since Btrfs can do “In-place ext3/4 conversion” (see: https://en.wi...
mdgm-ntgr
Mar 31, 2013NETGEAR Employee Retired
Whie the limitations with the utilities for creating/expanding the EXT4 filesystem have been fixed some things are required:
1. Update the kernel to one of the latest versions
2. Recreate the volumes with the new utility (would need to backup all data and do a factory default - wipes all data, settings, everything)
3. When expanding an array detect that a volume was created using the newer utility and use the new utility to expand the volume. When expanding an array created using an old utility still use the old expansion utility.
- Jul 15, 2018Retired_Member
