Kish
Mar 22, 2013Aspirant
Questions about OS 6
After reading up on Btrfs, I also do NOT understand the logic in not allowing current ARM and x86 Series owners to upgrade to OS 6. Since Btrfs can do “In-place ext3/4 conversion” (see: https://en.wi...
mdgm-ntgr
Apr 01, 2013NETGEAR Employee Retired
Yes. You have to recreate the filesystem with the newer utility and then expand it using the newer utility. The newer utility for expansion doesn't work with filesystems created using the older utility.
- Jul 15, 2018Retired_Member
