Kish
Mar 22, 2013Aspirant
Questions about OS 6
After reading up on Btrfs, I also do NOT understand the logic in not allowing current ARM and x86 Series owners to upgrade to OS 6. Since Btrfs can do “In-place ext3/4 conversion” (see: https://en.wi...
mangrove
Apr 01, 2013Apprentice
If you are talking about 32-bit vs 64-bit EXT4 inodes, that is completely besides the point. Your argument was that a new filesystem was needed. But the "new filesystem" could just as easily have been 64-bit EXT4. e2fstools support larger volumes than 16TB since 2011. But admittedly the specifics of your points are hard to analyze, as you are not giving any.
You are not exactly helping NTGR by dronelike repeating of the exact same arguments. Especially when they are not good. :D
- Jul 15, 2018Retired_Member
