AllWin
May 26, 2012Aspirant
Radiator 5.3.5 - problems with permissions
Hi, i have created "Public" share available for everyone (with anonymous access) to read and write. Also i have enable automatic permission management as see on this picture: But for some rea...
AllWin
May 28, 2012Aspirant
mdgm wrote: On the v2 you should be able to go to the Dashboard click Configure, go to Add-Ons > Installed and select Transmission. You should then seen an option the settings.json within the web-interface.
Yes i can, but for some reason after saving settings Transmission won't start anymore ("service failed to start"). When i try to edit settings.json for second time, i see in it only 10-15 lines of options, instead of 70+. Looks like only part of settings being saved. Although i have no issues with it if i do everything manually.
