DavidBulluss
Sep 08, 2014Aspirant
RadyNas DUO V2 / SBTouch / FLAC 24/192
When playing these files via Touch (with EDO app to enable 24/192) there is buffering every few seconds. I am exploring a myriad of possible issues but would like to check the load on the Nas processo...
mdgm-ntgr
Sep 09, 2014NETGEAR Employee Retired
What app or other service are you using to stream the music?
The Duo v2 does not have a powerful processor. If the audio is not in the right format to play on your client device or is too high quality to stream over your network then you will run into issues.
