CharlesR
Dec 01, 2014Guide
RAID with JBOD
With 6.2 is there anyway to have a raid (two or more disks) and still have a separate addressable drive "outside" of the raid itself? I know it doesn't make sense but I might want to setup a dedicated...
mdgm-ntgr
Dec 01, 2014NETGEAR Employee Retired
You would disable X-RAID, destroy the default volume and create the volumes you want. You could create a volume that uses just the one disk.
