CharlesR
Dec 01, 2014Guide
RAID with JBOD
With 6.2 is there anyway to have a raid (two or more disks) and still have a separate addressable drive "outside" of the raid itself? I know it doesn't make sense but I might want to setup a dedicated...
mdgm-ntgr
Dec 01, 2014NETGEAR Employee Retired
Well if some drive bays are empty, you could simply disable X-RAID, add a disk and create a new volume for the added disk. You can use a mixture of multiple drive and single drive volumes. Volumes don't have to all use the same RAID level.
