CharlesR
Dec 01, 2014Guide
RAID with JBOD
With 6.2 is there anyway to have a raid (two or more disks) and still have a separate addressable drive "outside" of the raid itself? I know it doesn't make sense but I might want to setup a dedicated...
vandermerwe
Dec 03, 2014Master
You can do this between OS 6 devices, if you transfer the disks into a unit with different architecture you would need to do so with its power off, then do an OS reinstall using the boot menu.
I am not certain whether you could take a disk from legacy unit and put it into any of the current line of devices.
Obviously you can't do this with only part of an array.
