rrmen1955
Jun 04, 2020Aspirant
raid1 on 628x
how can i setup raid1 using an 8 bay 628x, with 8x10t drives
- Jun 04, 2020
rrmen1955 wrote:
I have some very precious an valuable data, I need to store. Raid 1 on 8x10tb harddrives should yield me approx 40tb completely redundant. The same data written on 2 disks. however, when i configure for raid1, it changes to raid6. I cant figure out how to make it stay raid1I think you are confused on your RAID modes.
If you truly want RAID1, then you need to create 4 volumes, one for each pair of drives. Each volume is 10 TB, and has two drives that are mirrored. So 40 TB of total space. But you need to manually create shares on each volume and balance the space.
But from what you say, it sounds like you actually want RAID10. This is a hybrid RAID mode (1+0) that is described here: https://en.wikipedia.org/wiki/Nested_RAID_levels#RAID_10_(RAID_1+0) It would give you a 40 TB volume, comprised of mirrored pairs.
RAID6 would protect against any combination of 2 disk failures, but always fails with 3 or more disk failures. RAID10 fails with some combinations of two disk failures, but will succeed with some combinations of 3 or more drive failures.
Please read through the wiki article, and get back to us on the raid mode you want.
FWIW, RAID in any form isn't enough to keep your data safe. It is helpful, but you do need a backup of your data on other devices in order to keep your data safe.
rrmen1955
Jun 04, 2020Guru - Experienced User
- rrmen1955Jun 04, 2020Aspirantas the article says raid1 is mirrored disk, the same data written to 2 disks, giving me 40tb out of the 80tb. if any 1 disk fails it may be replaced without loss
- rrmen1955Jun 04, 2020Aspiranti understand the need for offline backup, this is to have another level of security.
- rrmen1955Jun 04, 2020Aspiranti will try creating 4 volumes of (2x10tb) giving me 10tb each volume, as you suggest. i was trying to create 1 volume (8x10tb) for 40tb usable. i will let you know if this works
- StephenBJun 05, 2020Guru - Experienced User
rrmen1955 wrote:
as the article says raid1 is mirrored disk, the same data written to 2 disks, giving me 40tb out of the 80tb.Well, no. As the article says "RAID 1 consists of an exact copy (or mirror) of a set of data on two or more disks; a classic RAID 1 mirrored pair contains two disks." If you set up a single RAID1 volume using all 8 disks, you'd have a 10TB volume that was mirrored on all the disks. Anything written to the volume would be written to all the disks.
The ReadyNAS won't let you do that - it just supports the "classic RAID 1" in the article. A mirrored pair of exactly two disks.
rrmen1955 wrote:
i was trying to create 1 volume (8x10tb) for 40tb usableThat would be RAID10, not RAID1.
As far as redundancy goes, the main difference is that if you ran into a case where redundancy fails (requiring at least 2 disk failures), with RAID10 you'd lose the entire volume. With RAID1 you'd only lose the specific volumes where both disks had failed. Either way you'd need to restore at least some data from backup.
Practically speaking, the main disadvantage of using 4 volumes is that you need to roughly balance the space used on each one (keeping adequate free space on each, and making sure the largest share fits comfortably on a 10 TB volume).
- rrmen1955Jun 05, 2020Aspirantthats why i am doing as the person said yesterday, make 4 volumes.
