Joe-9O
May 27, 2019Aspirant
RAIDar 6.5.0(on Win 10) not finding NAS (NV+, ProPioneer, RN214)
(I spent a while looking at other postings but they either don't work for me or not quite relevant.) I have RAIDar 6.5.0 running on 2 laptops running Win10. I also have Raidar 6.5.0 running on a ...
- May 28, 2019
Joe-9O wrote:
The Macbook is on Wifi and one of the two Windows 10 laptops.
The other is wired ethernet.
That rules out the router, since if it is blocking the traffic it would affect both WiFi connected devices.
Have you tried allowing RAIDar using this: https://pureinfotech.com/allow-apps-firewall-windows-10/
May 27, 2019Guru - Experienced User
Joe-9O wrote:
I have RAIDar 6.5.0 running on 2 laptops running Win10. I also have Raidar 6.5.0 running on a MacBook laptop. The 3 NAS fileservers (NV+, ProPioneer, RN214) are found by Raidar on the MacBook Pro. I cannot access the fileshares on the MacBook but I understand that this is a known limitation for macos.
You should be able to access the fileshares on the macbook.
Joe-9O wrote:
However, on my Windows 10 laptops, the 3 NAS fileservers are not dissovered by RAIDar. Even after I disable Defender firewall. In all cases (MacBook Pro, and 2 Windows laptops) I can map to the file shares independently of RAIDar. My router is a Netgear R8500 with each NAS unit is on a fixed IP.
Well you don't actually need to run RAIDar very often and you can reach the NAS web ui without it.
But the issue has to be that something is blocking broadcast traffic on the laptops. Is Defender the only security software you are running.
Joe-9O
Thank you. Defender and whatever is default on Windows 10 is all that is running.
I tried disabling Defender firewalls but it did not make a difference.
