Joe-9O
May 27, 2019Aspirant
RAIDar 6.5.0(on Win 10) not finding NAS (NV+, ProPioneer, RN214)
(I spent a while looking at other postings but they either don't work for me or not quite relevant.) I have RAIDar 6.5.0 running on 2 laptops running Win10. I also have Raidar 6.5.0 running on a ...
- May 28, 2019
Joe-9O wrote:
The Macbook is on Wifi and one of the two Windows 10 laptops.
The other is wired ethernet.
That rules out the router, since if it is blocking the traffic it would affect both WiFi connected devices.
Have you tried allowing RAIDar using this: https://pureinfotech.com/allow-apps-firewall-windows-10/
Joe-9O
Thank you. Defender and whatever is default on Windows 10 is all that is running.
I tried disabling Defender firewalls but it did not make a difference.
May 28, 2019Guru - Experienced User
RAIDar sends out broadcast packets to discover the various NAS, and the NAS respond with their own broadcast packets. That allows RAIDar to find the NAS even if the IP configuration of the NAS is mismatched to the network. But internet security software and sometimes routers get in the way (blocking broadcast packets for various reasons).
Is the Mac connected with ethernet or wifi? How about the PCs?
