Joe-9O
May 27, 2019Aspirant
RAIDar 6.5.0(on Win 10) not finding NAS (NV+, ProPioneer, RN214)
(I spent a while looking at other postings but they either don't work for me or not quite relevant.) I have RAIDar 6.5.0 running on 2 laptops running Win10. I also have Raidar 6.5.0 running on a ...
- May 28, 2019
Joe-9O wrote:
The Macbook is on Wifi and one of the two Windows 10 laptops.
The other is wired ethernet.
That rules out the router, since if it is blocking the traffic it would affect both WiFi connected devices.
Have you tried allowing RAIDar using this: https://pureinfotech.com/allow-apps-firewall-windows-10/
Joe-9O
May 28, 2019Aspirant
Thank you. That is helpful to know.
May 28, 2019Guru - Experienced User
- Joe-9OMay 28, 2019Aspirant
Thank you!! This solved my problem!
