rteguy
Dec 11, 2015Aspirant
RAIDar and changing IP addresses of NAS
Our network has two subnets (a 10. and 192.) the 192 needs to go away and that is the network the ReadyNAS are on. I have RAIDar on a PC on the 192 network. It says v4.3.8. RAIDar on the 10. network ...
rteguy
Dec 14, 2015Aspirant
Yes, I meant VIA RAIDar. I always think there is very little you can do in RAIDar but you can hit setup, which opens a a browser page. I would make the change in there.
Thanks.
StephenB wrote:RAIDar can't change the IP address, it can only display it. Of course you can change the NAS IP address from the NAS web ui. Perhaps you are launching that from RAIDar?
BrianL2
Dec 14, 2015NETGEAR Employee Retired
Hi rteguy,
Just to add, if your ReadyNAS has two NICs it can support your two subnets and should work with no problem.
Let us know if you have further questions.
Kind regards,
BrianL
NETGEAR Community Team
