bedlam1
Sep 25, 2017Prodigy
RAIDar diagnostics reporting "Volume swap is 100.00% full"
RAIDar diagnostics is reporting that "Volume swap is 100.00% full", what does this mean and should I be concerned? The content of mem_info log is: MemTotal: 1003608 kB MemFree: 67...
- Sep 28, 2017
Skywalker thanks for the offer re logs
I am going to pass on that just for now due to other problems I have trying to replace two drives, as I only have around 2TB of data I just started a Factory Default to solve this.
If the "Volume swap is 100.00% full" message is still there after completion I will send the logs.
Sep 26, 2017Guru - Experienced User
My RN526 says it has a 1 GB swap partition (/dev/md1). Possibly that's what it means.
I suggest rebooting the NAS, and then check the RAIDar status again.
- bedlam1Sep 26, 2017Prodigy
Have rebooted several times and still shows "Volume swap is 100.00% full"
Using putty I can see an entry in /dev
Name "+md1" Size "9,1" Modify Time "Sep 26 15:50"
I am not well enough versed in Linux to interpret that, where are you seeing your reference to dev/md1 Stephen?
