bedlam1
Sep 25, 2017Prodigy
RAIDar diagnostics reporting "Volume swap is 100.00% full"
RAIDar diagnostics is reporting that "Volume swap is 100.00% full", what does this mean and should I be concerned? The content of mem_info log is: MemTotal: 1003608 kB MemFree: 67...
- Sep 28, 2017
Skywalker thanks for the offer re logs
I am going to pass on that just for now due to other problems I have trying to replace two drives, as I only have around 2TB of data I just started a Factory Default to solve this.
If the "Volume swap is 100.00% full" message is still there after completion I will send the logs.
bedlam1
Sep 26, 2017Prodigy
Have rebooted several times and still shows "Volume swap is 100.00% full"
Using putty I can see an entry in /dev
Name "+md1" Size "9,1" Modify Time "Sep 26 15:50"
I am not well enough versed in Linux to interpret that, where are you seeing your reference to dev/md1 Stephen?
Sep 26, 2017Guru - Experienced User
root@NAS:~# swapon --show
NAME TYPE SIZE USED PRIO
/dev/md1 partition 1022.9M 2.2M -1
root@NAS:~#
- StephenBSep 28, 2017Guru - Experienced User
bedlam1 wrote:
Thanks StephenB
I am not seeing any entry after using that command
Something is wrong then, but I'm not sure how serious it is. If you've upgraded the memory in the pro above the 1 GB stock ram, then it probably matters less.
Hopefully someone from Netgear will chime in on how to fix it.
- SkywalkerSep 28, 2017NETGEAR Expert
The swap entry in the diagnostics log is a bug, and it's fixed in the upcoming Beta 3 (probably later today). But you might as well send in your logs so we can make sure everything else is working normally.
