bedlam1
Sep 25, 2017Prodigy
RAIDar diagnostics reporting "Volume swap is 100.00% full"
RAIDar diagnostics is reporting that "Volume swap is 100.00% full", what does this mean and should I be concerned? The content of mem_info log is: MemTotal: 1003608 kB MemFree: 67...
- Sep 28, 2017
Skywalker thanks for the offer re logs
I am going to pass on that just for now due to other problems I have trying to replace two drives, as I only have around 2TB of data I just started a Factory Default to solve this.
If the "Volume swap is 100.00% full" message is still there after completion I will send the logs.
Skywalker
Sep 28, 2017NETGEAR Expert
The swap entry in the diagnostics log is a bug, and it's fixed in the upcoming Beta 3 (probably later today). But you might as well send in your logs so we can make sure everything else is working normally.
bedlam1
Sep 28, 2017Prodigy
