Dave_K
Sep 08, 2015Aspirant
RAIDar finds, but cannot browse ReadyNAS Pro 6 - "Element not Found."
I have both a ReadyNAS NV and a ReadyNAS Pro 6 connected to my home network, along with two high end PCs running Windows 10 Pro 64 bit. RAIDar 4.3.8 has no problem locating and running Setup for bot...
Sep 08, 2015Guru - Experienced User
What happens if you go directly to the IP address in the browser? That is, https://proipaddress/admin
- Dave_KSep 08, 2015Aspirant
https://192.168.xx.yyy/admin or http://192.168.xx.yyy/admin both work just fine - bringing me to the Shares screen after logging in.
- StephenBSep 09, 2015Guru - Experienced User
The shares screen????
Or the home page of the admin ui?
It should be the latter (and look like the attached screenshot).
BTW, there is no reason to be afraid to post the full 192.168.x.y addresses. They are not routable over the internet. As you can see from my screen shot, my pro is assigned 10.0.0.10. That's not routable either, so you can't reach my NAS using that address.
- Dave_KSep 09, 2015Aspirant
I rebooted and tried it again. You are correct. I get to shares if I leave /admin off the path, which is what I must've typed. https://192.168.0.100/admin brings me to the home page of the admin ui.
