Numb3r6's avatar
Numb3r6
Apprentice
Feb 13, 2019
ReadyNAS Duo v1 boot fail into "Volume scan found and corrected errors"
This is a ReadyNAS Duo v1
-Bootup via Power Timer, as usual, no errors reported or emailed to me
-First use of NAS was to stream music to a mobile device. Done it many times, no issues. This time though the streamer was clearly struggling finally reporting it could not connect to device (i.e. the NAS)
-Visually checking it the blue LED was flashing at a steady rate but the unit was not finishing boot.
-No errors previously noted
-Held the power button down to force shutdown, which it did, and I removed power briefly
-Restarted, same
-Repeated this and eventually the blue LED went steady, but system still inaccessible
-Looking at the green LEDs, the top one (disk activity) was flashing rapidly and the 2 beneath it (disk 1 and 2) were steady.
-The IP address was then visible on the network, but could not connect to Frontview via a browser
-Left it a while longer and could access content via network, as well as using Frontview
-Checking Frontview logs etc, there's nothing worrying about disk health
-Only clue is in logs, just saying "Volume scan found and corrected errors"
Now I can access the file system I'm doing a (slightly overdue) backup to a standalone disk. It'll take a while....
With that in mind, I am puzzled as to what has happened. I'm pretty sure the timing coincided with my use of Stratospherix MusicStreamer.
So are there any known triggers that could provoke the symptoms I experienced, or is there anywhere else I can look at within the NAS for more detailed error info?
Storage is at 76% BTW
RAIDar shows no issues
thanks
Dave
  • I wouldn't be concerned about lp stat events.
    A volume scan is a reasonable idea, though I'd suggest making a backup (or updating it if needed) first.
  • StephenB's avatar
    Did you check system.log and kernel.log for details on what the volume scan fixed?  Also, did you look for any disk errors in those logs?
    • Numb3r6's avatar
      Numb3r6
      Apprentice
      Thanks for reply StephenB. OK I'd been looking in the file system rather than using the Frontview option to download them. I hadn't realised that option would reveal more detail than is shown in the Frontview summary. That said I don't know what I would be looking for that relates to the event that took place. System has not been rebooted since yesterday, as I am offloading content to another drive. Mind you it has shown no signs of misbehaviour nor anything bad in the Frontview health summary since.
      Whilst my system is far from new, I have replaced disks for higher capacity in its life, and regularly give it a blowthrough to shift dust. Mind you heat has never been an issue, and the only times I've had problems before (maybe twice, before I got a UPS) was unplanned power interruption which it recovered from anyway, with no signs afterwards.
      • StephenB's avatar
        It's hard to say if the file system corruption led to the streaming problem, or if the forced shutdown did.
        The forced shutdown would trigger a volume scan on startup, and possibly a RAID resync.  There could have been some lost (cached) writes, which would account for some filesystem corruption.
        Generally - look in system.log and kernel.log for any evidence of system crashes or disk-related errors between the time you had the streaming problem and the time the system was fully recovered.
        Also look in disk_usage.log at the fullness of the 2 GB OS partition (/dev/hdc1 if you are running XRAID).  Normally the OS partition on the Suo is about 25% full.
        disk_smart.log is a good place to look for information on disk health - you can also see the SMART+ stats in frontview (though they will come up blank if you use Chome).
