Warrenjelliott
Jul 29, 2015Aspirant
Raidar finds Netgear storage but says it is not accessible
Correct wording is Your NETGEAR Storage is not accessible from this computer, please check your network setting. Interestingly I was able to access it from this mac yesterday and increase my time...
- Oct 20, 2015
Hi all. Not replacing drives. Mac computers only. Re set and re booted NAS then reset Google as their double secure system didnt help. All working now with new updates.
Thanks for all your help.
Oct 18, 2015Guru - Experienced User
amator wrote:
replacing, 1 drive before
I am thinking your problem is now resolved. Is that correct?
amator
Oct 18, 2015Aspirant
Yes :)
- HH93Oct 20, 2015Aspirant
Hello,
I have the same probelm with access but after a different action.
I have a ReadyNAS 102 with the four HDD installed in the wrong order. I have order of 4TB, 4TB, 6TB, 6TB. And after discussions on another thread wished to back them up and move the HDD around to 6Tb, 6TB, 4TB, 4TB. There is 3.75TB of data on them in X-Raid set up/
I plugged in a 5TB External HDD to the front and rear USB Port in turn and when i triedto open it up on NetRaidar & via 10.0.1.xxx received the same message. I tried to reboot with the USB connected to the Front then the rear and again with the External HDD disconnected and still cant access the NAS !
Cannot access via Finder or windows explorer now either - so i am effectivly locked out of my data.
any ideas ?
Regards
Howie
- StephenBOct 20, 2015Guru - Experienced User
I think you mean RN104. Just to make sure there is no confusion here - simply reordering the drives will not help you. You need to recreate the volume (or do a factory install) with all disks in place. All data on the drives would be lost - so you need to back it up.
What firmware are you running?
- HH93Oct 22, 2015Aspirant
to StephenB:
Yes ReadyNAS 104 - and Firmware V 6.4
And yes I'm aware that just reodering the Disks isnt the way to go. Thats why I have bought a 5TB USB drive to back all the data onto.
Also to confirm - if i plug in a USB Drive to either front or Rear USB Ports the ReadyNAS freeses most of the time. If you look at the log entries i have tried to cut & paste there is a gap of three hours from 16:13 to 19:51 where i just left it to see if it would sort itself out. only way to get a responce was to cut the power and reboot it afterwards.
The drive is a seagate ST5000DM000-1FK178 which is sometimes seen and i have triedto Format - thinking the NAS would format it the way it liked.
Wed Oct 21 2015 19:51:50 Volume: Resyncing started for Volume spare. Wed Oct 21 2015 19:51:50 Volume: Resyncing started for Volume data. Wed Oct 21 2015 19:51:47 System: ReadyNASOS background service started. Wed Oct 21 2015 19:51:08 System: ReadyNASOS service or process was restarted. Wed Oct 21 2015 16:13:32 System: External storage device (null) is busy; try later. Wed Oct 21 2015 16:13:35 System: External storage device disconnected. Wed Oct 21 2015 16:13:32 System: External storage device disconnected. Wed Oct 21 2015 16:00:00 Backup: Deleted backup job Backup_1. Wed Oct 21 2015 15:57:28 System: External storage device ST5000DM000-1FK178 is busy; try later. Wed Oct 21 2015 15:57:22 System: External storage device disconnected. Wed Oct 21 2015 15:54:06 System: Format Complete. Wed Oct 21 2015 15:53:52 System: Format started. Wed Oct 21 2015 15:40:55 System: External storage device connected. Wed Oct 21 2015 15:40:47 System: External storage device connected. Wed Oct 21 2015 15:38:52 System: External storage device disconnected. Wed Oct 21 2015 15:38:50 System: External storage device disconnected. Wed Oct 21 2015 15:33:44 System: External storage device connected. Wed Oct 21 2015 15:33:35 System: External storage device connected. Wed Oct 21 2015 15:24:12 System: External storage device (null) is busy; try later. Wed Oct 21 2015 15:24:12 System: External storage device disconnected.
- HH93Oct 23, 2015Aspirant
Hi again,
progresss report.
So I pluged the External drive into a windows computer and formatted it to a single partition of 5TB.
Shut down normally the ReadyNAS and plugged the USB HDD into a rear Port as the manual states they are USB3 and the front is USB2.
Booted up the ReadyNAS again and it sees the USB Disk and for what it is also. so thats good.
Presently performing a back up of all data to it.
One strange thing is when browsing under Media are there folders - USB_HDD_1, USB_HDD_2, USB_HDD_3 when there is only one physically there !
Also there are no size details of these folders so i had to guess that 3 is the one to back up to.
regards
Howie
