anechka_t
Dec 30, 2012Aspirant
RAIDar won't run, help!
I recently upgraded my mac to 10.7.5 and I can access ReadyNas via APF with no issues. However, I'm unable to run RAIDar utility. When I try to run it, I get the following message: "To open “RAIDa...
anechka_t
Here's the copy of the error log file in the RAIDar directory:
java.lang.NullPointerException
[cid:0x91f58dba]send packet IOException[/192.168.1.105:49869]:java.io.IOException: Network is down
[cid:0x91f58dba]failed to send primer packet:com.infrant.jIproxy.IproxyException: failed to send packet [IOException]
