tomg35
Apr 20, 2014Aspirant
RAIDer - No JVM could be found on your machine
Hi, My machine is Windows 801 64 bit. I recently had an auto update on Java and since the update RAIDer has stopped working and gives the following error message No JVM could be found on your ma...
Apr 20, 2014Guru - Experienced User
Try going into Start -> All Apps -> Control panel -> System -> Advanced System Settings -> Advanced -> Environment variables (on the PC).
If EXE4J_JAVA_Home isn't there, then add it (pointing to the JRE folder).
