tomg35
Apr 20, 2014Aspirant
RAIDer - No JVM could be found on your machine
Hi, My machine is Windows 801 64 bit. I recently had an auto update on Java and since the update RAIDer has stopped working and gives the following error message No JVM could be found on your ma...
tomg35
Apr 21, 2014Aspirant
Success!!
I uninstalled Java again and also ran CCleaner. I looked in System 32 (and in the C drive) for any mention of Java but all the instances that I could see were in program folders for specific applications and I thought it best to leave those in place, I again downloaded Java from www.java.com and installed it - Looking in add\remove programs I noted that it just mentions java, whereas before it specifically mentioned that the install was 64 bit (checking the Program Files folders and Java can only be found in the folder Program Files (x86)).
RAIDer now works fine.
Thanks a lot for your help and quick replies.
